소개
This guide will display the step-by-step process of fixing and/or replacing a faulty antenna. Soldering may be involved, so be prepared!
필요한 것
First, apply pressure with your thumb on the top of the battery cover.
Next, pull down on the cover until it begins to slide.
Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
다른 5명이 해당 안내서를 완성하였습니다.
