주요 콘텐츠로 건너뛰기
Midland X-tra Talk Radio LXT118 Antenna Replacement
필요한 것
  1. Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: 1 단계, 이미지 1/2 Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: 1 단계, 이미지 2/2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Antenna Replacement: 2 단계, 이미지 1/1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Antenna Replacement, Case: 3 단계, 이미지 1/1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Antenna Replacement: 4 단계, 이미지 1/1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Antenna Replacement, Antenna: 5 단계, 이미지 1/1
    • Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
  6. Midland X-tra Talk Radio LXT118 Antenna Replacement: 6 단계, 이미지 1/1
    • Check the connection of the antenna with your eyes and fingers. The connection should be firm and smooth where it was soldered.
    • Ensure that the spring of the antenna isn't crooked or damaged by rubbing your fingers along the length of the spring.
    • Desolder the connection of the antenna to the motherboard. Careful!, if used improperly, the soldering tool can damage the circuit board!
  7. Midland X-tra Talk Radio LXT118 Antenna Replacement: 7 단계, 이미지 1/1
    • After obtaining a new or undamaged spring, solder it back onto the circuit board. Again, this is a delacate process as the soldering tool will be hot!
결론
다른 5명이 해당 안내서를 완성하였습니다.
Andre Nguyen
회원 가입일: 01/18/13
108 평판
안내서 1개 작성함
Cal Poly, Team 19-43, Regan Winter 2013 Cal Poly, Team 19-43, Regan Winter 2013 회원
CPSU-REGAN-W13S19G43
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 18
전체 시간: 2,097
