소개
This installation guide should be used when the batteries for the radio are out of power and new batteries need to be installed. The troubleshooting guide for this process can be found here.
부품
부품은 필요하지 않습니다.
  1. First, apply pressure with your thumb on the top of the battery cover.
    • First, apply pressure with your thumb on the top of the battery cover.
  2. Next, pull down on the cover until it begins to slide.
    • Next, pull down on the cover until it begins to slide.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  5. Put the new batteries into their slots in the back case.
    • Put the new batteries into their slots in the back case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
James Tucker Dunn
회원 가입일: 2013년 01월 18일
371 평판
안내서 6개 작성하였습니다
Cal Poly, Team 19-43, Regan Winter 2013 Cal Poly, Team 19-43, Regan Winter 2013 회원
CPSU-REGAN-W13S19G43
3 회원들
안내서 9개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 62
전체 시간: 6,732
