주요 콘텐츠로 건너뛰기
Midland X-tra Talk Radio LXT118 Front buttons Replacement
필요한 것
  1. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Batteries: 1 단계, 이미지 1/2 Midland X-tra Talk Radio LXT118 Front buttons Replacement, Batteries: 1 단계, 이미지 2/2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Front buttons Replacement: 2 단계, 이미지 1/1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Case: 3 단계, 이미지 1/1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Front buttons Replacement: 4 단계, 이미지 1/1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Front buttons: 5 단계, 이미지 1/1
    • Once the back case is already off, use your fingers to lift up the circuit board from the side opposite the antenna.
  6. Midland X-tra Talk Radio LXT118 Front buttons Replacement: 6 단계, 이미지 1/1
    • Lay the circuit board down on the side, as you will not want it interfering with your work on the buttons!
  7. Midland X-tra Talk Radio LXT118 Front buttons Replacement: 7 단계, 이미지 1/1
    • Grasp the rubber cast around the buttons from one side, and slowly lift upwards. Make note of which way the buttons fit into the plastic casing!
    • At this point, the buttons can be cleaned in accordance with the radio buttons are stuck or sticking troubleshooting guide.
    • The speaker does not need to removed in order to get to the buttons.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Logan
회원 가입일: 01/17/13
282 평판
안내서 2개 작성하였습니다
Cal Poly, Team 19-43, Regan Winter 2013 Cal Poly, Team 19-43, Regan Winter 2013 회원
CPSU-REGAN-W13S19G43
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 1,028
