주요 콘텐츠로 건너뛰기
Mill Cutter Paper Stripper Replacement
필요한 것
  1. Mill Cutter Paper Stripper Replacement, Mill cutter paper stripper set and stripper guide set: 1 단계, 이미지 1/1
    • Unplug the shredder from the wall electrical outlet.
    • Remove the shredder from its catch basket and place it face down on a flat surface.
  2. Mill Cutter Paper Stripper Replacement: 2 단계, 이미지 1/3 Mill Cutter Paper Stripper Replacement: 2 단계, 이미지 2/3 Mill Cutter Paper Stripper Replacement: 2 단계, 이미지 3/3
    • Locate the seven case screws and remove them with a Phillips screwdriver. The screws are identified by the seven marked circles. The screws are 15 mm in length and the head diameter is 5 mm.
    • Remove the manufacturer’s label in order to get to one of the hidden screws, if applicable.
  3. Mill Cutter Paper Stripper Replacement: 3 단계, 이미지 1/2 Mill Cutter Paper Stripper Replacement: 3 단계, 이미지 2/2
    • Remove the screws connecting the stripper guide and the base of the shredder's housing unit with a Phillips screwdriver. The diameter head and screws are 10 mm in length.
  4. Mill Cutter Paper Stripper Replacement: 4 단계, 이미지 1/2 Mill Cutter Paper Stripper Replacement: 4 단계, 이미지 2/2
    • Once all of the screws have been removed, pull the casing apart.
    • Remove the stripper guide from the housing unit.
    • Use caution to prevent the trigger guard from falling apart.
  5. Mill Cutter Paper Stripper Replacement: 5 단계, 이미지 1/3 Mill Cutter Paper Stripper Replacement: 5 단계, 이미지 2/3 Mill Cutter Paper Stripper Replacement: 5 단계, 이미지 3/3
    • Remove the e-clips from the gears on the left side with a flathead screwdriver.
    • Remove screws from the gear box cover on the right side with a Phillips screwdriver. The screws are identified by the two marked circles. The screws are 7 mm in length and the head diameter is 3 mm.
  6. Mill Cutter Paper Stripper Replacement: 6 단계, 이미지 1/3 Mill Cutter Paper Stripper Replacement: 6 단계, 이미지 2/3 Mill Cutter Paper Stripper Replacement: 6 단계, 이미지 3/3
    • Remove the gears from both sides.
    • If the gears are hard to remove, use a flathead screwdriver to help remove them. The gears also may be greasy so place them on a paper towel or newspaper.
    • Remove the screws from the gearbox side plate with Phillips screwdriver to get to the gears. The screws are 7 mm in length and the head diameter is 3 mm.
  7. Mill Cutter Paper Stripper Replacement: 7 단계, 이미지 1/2 Mill Cutter Paper Stripper Replacement: 7 단계, 이미지 2/2
    • Replace the mill cutter paper stripper set and stripper guide set.
    • Use protective gloves as the blades are very sharp.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Takisha Parrish
회원 가입일: 01/21/18
175 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 회원
USFSM-STEWART-S18S1G1
15 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 1,233
