주요 콘텐츠로 건너뛰기
Milton Bradley Simon Light Bulb Replacement
필요한 것
  1. Milton Bradley Simon Light Bulb Replacement, Light Bulb: 1 단계, 이미지 1/2 Milton Bradley Simon Light Bulb Replacement, Light Bulb: 1 단계, 이미지 2/2
    • Make sure the game is powered off by switching the On/Off switch to the left.
  2. Milton Bradley Simon Light Bulb Replacement: 2 단계, 이미지 1/1
    • Take off the green and red switches on top of the game by pulling them off.
  3. Milton Bradley Simon Light Bulb Replacement: 3 단계, 이미지 1/1
    • Flip the game over.
  4. Milton Bradley Simon Light Bulb Replacement: 4 단계, 이미지 1/1
    • Slide the battery cover off of the back.
  5. Milton Bradley Simon Light Bulb Replacement: 5 단계, 이미지 1/1
    • Take out the batteries.
  6. Milton Bradley Simon Light Bulb Replacement: 6 단계, 이미지 1/1
    • Use the Phillips Head screwdriver to unscrew the screws located at the four corners of the game.
  7. Milton Bradley Simon Light Bulb Replacement: 7 단계, 이미지 1/1
    • Pull off the back plastic case of the game.
  8. Milton Bradley Simon Light Bulb Replacement: 8 단계, 이미지 1/1
    • Carefully place the top half of the game aside.
    • The top half is the half with the colored panels. Carefully place this half aside so the buttons do not fall out of place.
  9. Milton Bradley Simon Light Bulb Replacement: 9 단계, 이미지 1/1
    • Unscrew the 4 light bulbs from the bottom half of the game.
결론
Follow these steps in reverse to reassemble the device.
Simon Redondo
회원 가입일: 02/10/16
113 평판
안내서 1개 작성함
Colorado Springs, Team 5-4, Mcmichael Spring 2016 Colorado Springs, Team 5-4, Mcmichael Spring 2016 회원
UCCS-MCMICHAEL-S16S5G4
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 22
30일 전: 75
전체 시간: 4,130
