주요 콘텐츠로 건너뛰기
Milwaukee 2780-20 (2) Ball Bearings Replacement
필요한 것
  1. Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: 1 단계, 이미지 1/3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: 1 단계, 이미지 2/3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: 1 단계, 이미지 3/3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 (2) Ball Bearings Replacement: 2 단계, 이미지 1/3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 2 단계, 이미지 2/3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 2 단계, 이미지 3/3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 (2) Ball Bearings Replacement: 3 단계, 이미지 1/1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 (2) Ball Bearings Replacement: 4 단계, 이미지 1/3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 4 단계, 이미지 2/3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 4 단계, 이미지 3/3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
  5. Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: 5 단계, 이미지 1/3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: 5 단계, 이미지 2/3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: 5 단계, 이미지 3/3
    • Using a Torx T20 screwdriver to remove four 6mm screws located on top of the gearcase assembly.
  6. Milwaukee 2780-20 (2) Ball Bearings Replacement: 6 단계, 이미지 1/2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 6 단계, 이미지 2/2
    • Pull the gearcase away from electronic assembly to expose the inside.
  7. Milwaukee 2780-20 (2) Ball Bearings Replacement: 7 단계, 이미지 1/2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 7 단계, 이미지 2/2
    • Using a 3/8 Wrench, Remove the nut located in the center of the Gearcase.
    • The nut and pinion should immediatley come apart from the rotor assembly.
  8. Milwaukee 2780-20 (2) Ball Bearings Replacement: 8 단계, 이미지 1/3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 8 단계, 이미지 2/3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 8 단계, 이미지 3/3
    • Pull the rotor assembly apart from the gearcase casing.
  9. Milwaukee 2780-20 (2) Ball Bearings Replacement: 9 단계, 이미지 1/3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 9 단계, 이미지 2/3 Milwaukee 2780-20 (2) Ball Bearings Replacement: 9 단계, 이미지 3/3
    • Using a Torx T15 screwdriver, remove the two 4mm screws to take the bearing retainer off.
  10. Milwaukee 2780-20 (2) Ball Bearings Replacement: 10 단계, 이미지 1/2 Milwaukee 2780-20 (2) Ball Bearings Replacement: 10 단계, 이미지 2/2
    • Use a hammer to knock out the bearing and begin installing the new one before reassembling.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Hopper
회원 가입일: 08/22/19
468 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 43
전체 시간: 2,977
