소개
This guide will show you how to replace the diaphragm assembly. A faulty diaphragm assembly can lead to a few different issues including irregular shaking, grinding, or leaking grease.
필요한 것
Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
to reasemble .
Which is the correct position of the Shift knob assembly ?
