주요 콘텐츠로 건너뛰기
Milwaukee 5262-21 Fan Baffle Replacement
필요한 것
  1. Milwaukee 5262-21 Fan Baffle Replacement, Housing Assembly: 1 단계, 이미지 1/1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Fan Baffle Replacement: 2 단계, 이미지 1/1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Fan Baffle Replacement, Fan Baffle: 3 단계, 이미지 1/2 Milwaukee 5262-21 Fan Baffle Replacement, Fan Baffle: 3 단계, 이미지 2/2
    • Now the two 10mm T-10 screws shown in red can be removed.
    • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
  4. Milwaukee 5262-21 Fan Baffle Replacement: 4 단계, 이미지 1/2 Milwaukee 5262-21 Fan Baffle Replacement: 4 단계, 이미지 2/2
    • Using the metal spudger, remove each brush holder as shown in the images.
  5. Milwaukee 5262-21 Fan Baffle Replacement: 5 단계, 이미지 1/3 Milwaukee 5262-21 Fan Baffle Replacement: 5 단계, 이미지 2/3 Milwaukee 5262-21 Fan Baffle Replacement: 5 단계, 이미지 3/3
    • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
  6. Milwaukee 5262-21 Fan Baffle Replacement: 6 단계, 이미지 1/2 Milwaukee 5262-21 Fan Baffle Replacement: 6 단계, 이미지 2/2
    • After removing the four screws, pull apart the the two sections.
  7. Milwaukee 5262-21 Fan Baffle Replacement: 7 단계, 이미지 1/2 Milwaukee 5262-21 Fan Baffle Replacement: 7 단계, 이미지 2/2
    • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
    • These screws hold the fan baffle in place.
  8. Milwaukee 5262-21 Fan Baffle Replacement: 8 단계, 이미지 1/2 Milwaukee 5262-21 Fan Baffle Replacement: 8 단계, 이미지 2/2
    • Remove the fan baffle by pulling it out.
결론
Andrew Floyd
회원 가입일: 03/08/19
277 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 UMass Dartmouth, Team S1-G3, Botvin Spring 2019 회원
UMASSD-BOTVIN-S19S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 604
