주요 콘텐츠로 건너뛰기
Milwaukee 5262-21 Motor Housing Replacement
필요한 것
  1. Milwaukee 5262-21 Motor Housing Replacement, Housing Assembly: 1 단계, 이미지 1/1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Motor Housing Replacement: 2 단계, 이미지 1/1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: 3 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: 3 단계, 이미지 2/2
    • Now the two 10mm T-10 screws shown in red can be removed.
    • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
  4. Milwaukee 5262-21 Motor Housing Replacement: 4 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement: 4 단계, 이미지 2/2
    • Using the metal spudger, remove each brush holder as shown in the images.
  5. Milwaukee 5262-21 Motor Housing Replacement: 5 단계, 이미지 1/3 Milwaukee 5262-21 Motor Housing Replacement: 5 단계, 이미지 2/3 Milwaukee 5262-21 Motor Housing Replacement: 5 단계, 이미지 3/3
    • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
  6. Milwaukee 5262-21 Motor Housing Replacement: 6 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement: 6 단계, 이미지 2/2
    • After removing the four screws, pull apart the the two sections.
  7. Milwaukee 5262-21 Motor Housing Replacement: 7 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement: 7 단계, 이미지 2/2
    • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
    • These screws hold the fan baffle in place.
  8. Milwaukee 5262-21 Motor Housing Replacement: 8 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement: 8 단계, 이미지 2/2
    • Remove the fan baffle by pulling it out.
  9. Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: 9 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: 9 단계, 이미지 2/2
    • Pull the black wire(shown in the image) out of the trigger assembly.
  10. Milwaukee 5262-21 Motor Housing Replacement: 10 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement: 10 단계, 이미지 2/2
    • Pull the white wire (shown in the image) out of the trigger assembly.
  11. Milwaukee 5262-21 Motor Housing Replacement: 11 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement: 11 단계, 이미지 2/2
    • Using a metal spudger slide the black wire (shown in the image) out of the trigger assembly.
  12. Milwaukee 5262-21 Motor Housing Replacement: 12 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement: 12 단계, 이미지 2/2
    • Using a metal spudger slide the yellow wire (shown in the image) out of the trigger assembly.
  13. Milwaukee 5262-21 Motor Housing Replacement: 13 단계, 이미지 1/3 Milwaukee 5262-21 Motor Housing Replacement: 13 단계, 이미지 2/3 Milwaukee 5262-21 Motor Housing Replacement: 13 단계, 이미지 3/3
    • After disconnecting the wires, push the 120v Field Assembly out of the motor housing.
    • You may need to use a screwdriver to push the assembly from behind.
  14. Milwaukee 5262-21 Motor Housing Replacement: 14 단계, 이미지 1/3 Milwaukee 5262-21 Motor Housing Replacement: 14 단계, 이미지 2/3 Milwaukee 5262-21 Motor Housing Replacement: 14 단계, 이미지 3/3
    • Once the assembly is loose, pull each half out of the housing.
    • Note the orientation of how the halves sit together in the housing before removal.
  15. Milwaukee 5262-21 Motor Housing Replacement: 15 단계, 이미지 1/2 Milwaukee 5262-21 Motor Housing Replacement: 15 단계, 이미지 2/2
    • Remove the motor housing from the device.
결론
Andrew Floyd
회원 가입일: 03/08/19
277 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 UMass Dartmouth, Team S1-G3, Botvin Spring 2019 회원
UMASSD-BOTVIN-S19S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 277
