소개
If you need to replace the motor housing in the rotary hammer, use this guide to take apart the device. You will be following a step by step guide, that will help you in replacing the motor house, you may also refer to the pictures attached to each step for guidance.
필요한 것
Now the two 10mm T-10 screws shown in red can be removed.
Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
거의 끝나갑니다!
결론
