주요 콘텐츠로 건너뛰기
Milwaukee 5262-21 Power Cord Replacement
필요한 것
  1. Milwaukee 5262-21 Power Cord Replacement, Housing Assembly: 1 단계, 이미지 1/1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Power Cord Replacement: 2 단계, 이미지 1/1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Power Cord Replacement, Power Cord: 3 단계, 이미지 1/2 Milwaukee 5262-21 Power Cord Replacement, Power Cord: 3 단계, 이미지 2/2
    • Remove the two 11.5mm T-15 screws shown in red.
  4. Milwaukee 5262-21 Power Cord Replacement: 4 단계, 이미지 1/3 Milwaukee 5262-21 Power Cord Replacement: 4 단계, 이미지 2/3 Milwaukee 5262-21 Power Cord Replacement: 4 단계, 이미지 3/3
    • Follow the black and white cord to the trigger.
    • On the trigger there are two small bolts that you have to loosen.
    • Loosen them slightly with a H - 1.5 bit.
  5. Milwaukee 5262-21 Power Cord Replacement: 5 단계, 이미지 1/3 Milwaukee 5262-21 Power Cord Replacement: 5 단계, 이미지 2/3 Milwaukee 5262-21 Power Cord Replacement: 5 단계, 이미지 3/3
    • Once the bolts are loose you can pull both cords straight out from the trigger.
    • Pull the cable from the chassis and put it to the side and it has been successfully removed.
결론
Adrien Andrade-Cain
회원 가입일: 03/08/19
181 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 UMass Dartmouth, Team S1-G3, Botvin Spring 2019 회원
UMASSD-BOTVIN-S19S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 287
