주요 콘텐츠로 건너뛰기
Milwaukee 5262-21 Reduction Gear Assembly Replacement
필요한 것
  1. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Housing Assembly: 1 단계, 이미지 1/1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: 3 단계, 이미지 1/2 Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: 3 단계, 이미지 2/2
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 4 단계, 이미지 1/2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 4 단계, 이미지 2/2
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 5 단계, 이미지 1/3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 5 단계, 이미지 2/3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 5 단계, 이미지 3/3
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 6 단계, 이미지 1/2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 6 단계, 이미지 2/2
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 7 단계, 이미지 1/3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 7 단계, 이미지 2/3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 7 단계, 이미지 3/3
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 8 단계, 이미지 1/2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 8 단계, 이미지 2/2
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 9 단계, 이미지 1/2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 9 단계, 이미지 2/2
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 10 단계, 이미지 1/2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 10 단계, 이미지 2/2
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 11 단계, 이미지 1/3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 11 단계, 이미지 2/3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 11 단계, 이미지 3/3
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Reduction Gear Assembly Replacement: 12 단계, 이미지 1/3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 12 단계, 이미지 2/3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: 12 단계, 이미지 3/3
    • Now pull the reduction gear assembly up and out of the diaphragm.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Payton Parker
회원 가입일: 03/08/19
534 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 UMass Dartmouth, Team S1-G3, Botvin Spring 2019 회원
UMASSD-BOTVIN-S19S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 8
전체 시간: 1,315
