소개
The back panel of the Milwaukee Circular Saw 263020 B57A 2008 is needed to access the internal parts of the device. If there is damage exposing electronics or a need to replace internal parts please refer to this guide to remove your back panel.
필요한 것
Remove the nine 6 mm screws using a Torx T4 screwdriver.
Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
