주요 콘텐츠로 건너뛰기
Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement
필요한 것
  1. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement, Outer Casing: 1 단계, 이미지 1/2 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement, Blade Clamping Mechanism: 2 단계, 이미지 1/1
    • Open up the device.
    • Remove the screws that are connecting the shoe to the gearbox using the T15 Torx screwdriver to remove 14.0 mm screws. You will need to pull out the shoe and gearbox to get to the screw on the other side.
  3. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 3 단계, 이미지 1/3 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 3 단계, 이미지 2/3 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 3 단계, 이미지 3/3
    • Using your finger, push the rubber band up to allow you to slide the shoe off of the blade clamping mechanism.
  4. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 4 단계, 이미지 1/3 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 4 단계, 이미지 2/3 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 4 단계, 이미지 3/3
    • Detach the gearbox from the motor.
    • Remove the screws from the gearbox to expose the blade camping mechanism, then pull out the blade clamping mechanism from the gearbox. Use a T15 Torx screwdriver to remove five 14.0 mm screws.
  5. Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 5 단계, 이미지 1/2 Milwaukee Hackzall 2625-20 Blade Clamping Mechanism Replacement: 5 단계, 이미지 2/2
    • Remove the external retaining ring.
    • Next, remove the frontcam.
    • Then, take out the pin.
    • Remove the cam collar.
    • Remove the sleeve.
    • Remove the torsion spring.
    • Lastly, remove the spring cover.
결론
Mason Jones
회원 가입일: 09/18/19
572 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 22
전체 시간: 2,552
