주요 콘텐츠로 건너뛰기
Milwaukee Hackzall 2625-20 Gearbox Replacement
필요한 것
  1. Milwaukee Hackzall 2625-20 Gearbox Replacement, Outer Casing: 1 단계, 이미지 1/2 Milwaukee Hackzall 2625-20 Gearbox Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Gearbox Replacement, Gearbox: 2 단계, 이미지 1/1
    • Open up the device.
    • Remove the screws that are connecting the shoe to the gearbox using the T15 Torx screwdriver to remove 14.0 mm screws.
    • Pull out the shoe and gearbox to remove the screw on the other side
  3. Milwaukee Hackzall 2625-20 Gearbox Replacement: 3 단계, 이미지 1/3 Milwaukee Hackzall 2625-20 Gearbox Replacement: 3 단계, 이미지 2/3 Milwaukee Hackzall 2625-20 Gearbox Replacement: 3 단계, 이미지 3/3
    • Using your finger, push the rubber band up then slide the shoe off of the blade clamping mechanism.
  4. Milwaukee Hackzall 2625-20 Gearbox Replacement: 4 단계, 이미지 1/3 Milwaukee Hackzall 2625-20 Gearbox Replacement: 4 단계, 이미지 2/3 Milwaukee Hackzall 2625-20 Gearbox Replacement: 4 단계, 이미지 3/3
    • Detach the gearbox from the motor.
    • Remove the screws from the gearbox to expose the blade camping mechanism, then pull out the blade clamping mechanism from the gearbox. You will use a T15 Torx screwdriver to remove 14.0 mm screws.
결론
Mason Jones
회원 가입일: 09/18/19
572 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 25
전체 시간: 1,918
