주요 콘텐츠로 건너뛰기
Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement
필요한 것
  1. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Battery: 1 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Battery: 1 단계, 이미지 2/2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 2 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 2 단계, 이미지 2/2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Brush Block Assembly: 3 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Brush Block Assembly: 3 단계, 이미지 2/2
    • Remove the two 6mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
  4. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 4 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 4 단계, 이미지 2/2
    • Pull the motor and brush block assembly out of the drill housing.
  5. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 5 단계, 이미지 1/1
    • The gear case is easily separated from the electric motor by gently pulling the two pieces apart.
  6. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 6 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: 6 단계, 이미지 2/2
    • Insert the opening pick between one of the carbon brushes and the electric motor to help compress the spring.
    • While compressing the spring slide that section of the brush block assembly over the bearing.
    • The brush block assembly should easily slide over the bearing now, if it does not repeat the above process as needed for the other three carbon brushes.
결론
BRYCE DICKERSON
회원 가입일: 09/05/19
483 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 28
전체 시간: 1,238
