주요 콘텐츠로 건너뛰기
Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement
필요한 것
  1. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Battery: 1 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Battery: 1 단계, 이미지 2/2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 2 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 2 단계, 이미지 2/2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Electric Motor: 3 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement, Electric Motor: 3 단계, 이미지 2/2
    • Remove the two 6mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
  4. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 4 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 4 단계, 이미지 2/2
    • Remove the gear case and electric motor assembly from the impact driver case by pulling up on it.
  5. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 5 단계, 이미지 1/1
    • The gear case is easily separated from the electric motor by gently pulling the two pieces apart.
  6. Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 6 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Electric Motor Replacement: 6 단계, 이미지 2/2
    • Insert the opening pick between one of the carbon brushes and the electric motor to help compress the spring.
    • While compressing the spring slide that section of the brush block assembly over the bearing.
    • The brush block assembly should easily slide over the bearing now , if it does not repeat the above process as needed for the other three carbon brushes.
    • When you remove the brush block assembly, the remaining component is the electric motor.
결론
BRYCE DICKERSON
회원 가입일: 09/05/19
483 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 26
전체 시간: 1,413
