주요 콘텐츠로 건너뛰기
Milwaukee Hex Impact Driver 2656-20 Trigger Assembly Replacement
필요한 것
  1. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: 1 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: 1 단계, 이미지 2/2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 2 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: 2 단계, 이미지 2/2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: 3 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: 3 단계, 이미지 2/2
    • Remove the two 6 mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
    • Move the two wires out of the way.
  4. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: 4 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: 4 단계, 이미지 2/2
    • Gently pull up on the trigger assembly to remove it from the case.
  5. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: 5 단계, 이미지 1/1
    • Remove the trigger assembly from the device.
결론
Troy Conrad
회원 가입일: 09/16/19
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 1,112
