주요 콘텐츠로 건너뛰기
Milwaukee Hex Impact Driver 2750-20 Driver Head Replacement
필요한 것
  1. Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Outer Casing: 1 단계, 이미지 1/1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement: 2 단계, 이미지 1/1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Driver Head: 3 단계, 이미지 1/3 Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Driver Head: 3 단계, 이미지 2/3 Milwaukee Hex Impact Driver 2750-20  Driver Head Replacement, Driver Head: 3 단계, 이미지 3/3
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
결론
Charles Putnam
회원 가입일: 02/12/19
409 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 592
