주요 콘텐츠로 건너뛰기
Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement
필요한 것
  1. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: 1 단계, 이미지 1/1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: 2 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: 2 단계, 이미지 2/2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement, Gear Case: 3 단계, 이미지 1/1
    • Set the cover aside so the drill body is visible and can be accessed.
    • The gear case is the silver cylinder part with a black tip in the top of the drill.
  4. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: 4 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: 4 단계, 이미지 2/2
    • Grip the gear case in one hand while holding the body of the drill with the other.
    • Pull outward to remove.
    • Remove carefully, being mindful of the connecting wires. Damage to these wires can cause permanent damage to the drill.
  5. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: 5 단계, 이미지 1/1
    • Check the connection from the motor to the trigger.
    • Check that the connection to the circuit board is intact.
    • If both connections are intact, the gears inside the gear case assembly may be jammed and need to be replaced.
  6. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: 6 단계, 이미지 1/1
    • A replacement part can be found on the Milawukee Tool Website under Part NO. 14-30-D012.
결론
Kaylee Rose
회원 가입일: 01/16/19
268 평판
안내서 3개 작성하였습니다
University of Alabama, Team S2-G3, Bedsole Spring 2019 University of Alabama, Team S2-G3, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S2G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 1,715
