주요 콘텐츠로 건너뛰기
Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement
필요한 것
  1. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: 1 단계, 이미지 1개 중 1개
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: 2 단계, 이미지 2개 중 1개 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: 3 단계, 이미지 2개 중 1개 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: 3 단계, 이미지 2개 중 2개
    • Locate the black forward/reverse button underneath the chuck.
    • Pull the button gently towards you to remove it from the trigger assembly.
  4. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: 4 단계, 이미지 1개 중 1개
    • Using replacement part NO. 45-24-D013 (forward/reverse shuttle), follow the steps of this guide in reverse order.
결론
작성자
2다른 기여자 명과 함께
Alex Larson
회원 가입일: 01/16/19
243 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 944
