주요 콘텐츠로 건너뛰기
Milwaukee Hole Hawg 1675-1 Field Replacement
필요한 것
  1. Milwaukee Hole Hawg 1675-1 Field Replacement, Motor Brushes: 1 단계, 이미지 1/1
    • Ensure that the drill is unplugged.
    • Position the drill so that it is on its side.
  2. Milwaukee Hole Hawg 1675-1 Field Replacement: 2 단계, 이미지 1/3 Milwaukee Hole Hawg 1675-1 Field Replacement: 2 단계, 이미지 2/3 Milwaukee Hole Hawg 1675-1 Field Replacement: 2 단계, 이미지 3/3
    • Remove the brush cap with a flathead screwdriver.
  3. Milwaukee Hole Hawg 1675-1 Field Replacement: 3 단계, 이미지 1/2 Milwaukee Hole Hawg 1675-1 Field Replacement: 3 단계, 이미지 2/2
    • Pry up on the copper brush holder with a screwdriver or spudger.
    • Continue lifting up the copper brush holder to remove the brush.
    • Repeat on the opposite side.
  4. Milwaukee Hole Hawg 1675-1 Field Replacement, Field: 4 단계, 이미지 1/2 Milwaukee Hole Hawg 1675-1 Field Replacement, Field: 4 단계, 이미지 2/2
    • Position the the drill upright and remove the four 19mm Torx T15 screws securing the motor cover.
  5. Milwaukee Hole Hawg 1675-1 Field Replacement: 5 단계, 이미지 1/3 Milwaukee Hole Hawg 1675-1 Field Replacement: 5 단계, 이미지 2/3 Milwaukee Hole Hawg 1675-1 Field Replacement: 5 단계, 이미지 3/3
    • Remove the motor cover and withdraw the armature.
    • Take note to not lose the washer that sits on top of the armature.
  6. Milwaukee Hole Hawg 1675-1 Field Replacement: 6 단계, 이미지 1/2 Milwaukee Hole Hawg 1675-1 Field Replacement: 6 단계, 이미지 2/2
    • Remove the black insulator ring.
    • Remove the two 45mm Torx T15 screws securing the field to the drill.
  7. Milwaukee Hole Hawg 1675-1 Field Replacement: 7 단계, 이미지 1/3 Milwaukee Hole Hawg 1675-1 Field Replacement: 7 단계, 이미지 2/3 Milwaukee Hole Hawg 1675-1 Field Replacement: 7 단계, 이미지 3/3
    • Position drill on its side.
    • Remove the four 19mm Torx T15 screws.
    • Remove the two 25mm Torx T27 screws.
    • Remove the top portion of the handle.
  8. Milwaukee Hole Hawg 1675-1 Field Replacement: 8 단계, 이미지 1/2 Milwaukee Hole Hawg 1675-1 Field Replacement: 8 단계, 이미지 2/2
    • Lift the switch up and away to allow room to work.
    • Uncrimp the wire connector on the yellow field wire attached to the switch to disconnect it.
  9. Milwaukee Hole Hawg 1675-1 Field Replacement: 9 단계, 이미지 1/1
    • Lift the field out of the device, feeding the yellow wire through the handle.
결론
Colby Green
회원 가입일: 01/13/20
183 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 619
