소개
Does your Milwaukee Hole Hawg 1675-1 drill have a loss of power or smoke coming from inside the cover when in use? If this is true, your field may be in need of replacing. Here is a link to the Milwaukee Hole Hawg 1675-1 Troubleshooting page. The armature spins inside the field causing an electromagnetic field that gives the drill its power. One reason your field may go out is because of an overload of stress put on the motor. All you will need is the torx T15H bit.
필요한 것
Position the the drill upright and remove the four 19mm Torx T15 screws securing the motor cover.
