주요 콘텐츠로 건너뛰기
Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement
필요한 것
  1. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: 1 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: 1 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: 1 단계, 이미지 3/3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove (6) 5 x 18mm screws with a T-20 screwdriver.
    • Remove (4) 5 x 14mm screws. with T-20 screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 2 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 2 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 2 단계, 이미지 3/3
    • Hold the device so the gray gearbox assembly faces directly towards you.
    • Remove the four screws with a T-20 screwdriver.
    • After removing all screws, use a small plastic opening tool to slide the gearbox assembly forward.
  3. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 3 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 3 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 3 단계, 이미지 3/3
    • Gently remove the upper clam shell.
    • Slide the motor and gearbox assembly out the front of the device and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The brushes may need to be compressed in order for the motor to be removed.
  4. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 4 단계, 이미지 1/2 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: 4 단계, 이미지 2/2
    • Remove the brushes from the mount by pulling the brush body directly upward.
    • Disconnect the blue wire from the lower brush.
    • Disconnect the white wire from the upper brush.
    • Reconnect the wires to the new brush and replace them back into the mount.
    • The brushes may need to be compressed in order to slide the motor back into position.
결론
Yuna Choi
회원 가입일: 09/18/19
387 평판
안내서 3개 작성하였습니다
댓글 한 개
Wear to find brushes for impact
Laurie Hathaway-Ashby - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 16
전체 시간: 647
