주요 콘텐츠로 건너뛰기
Milwaukee Impact Wrench 9070-20 Motor Field Winding Replacement
필요한 것
  1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: 1 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: 1 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: 1 단계, 이미지 3/3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 2 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 2 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 2 단계, 이미지 3/3
    • Remove the four screws on each corner of the gear box assembly using a T-20 Screwdriver.
    • Use a plastic opening tool, slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 3 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 3 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 3 단계, 이미지 3/3
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The motor brushes may need to be compressed to help with the removal of the gearbox assembly.
  4. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 4 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 4 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 4 단계, 이미지 3/3
    • Disconnect the black AC wire from the brown field wire.
    • Disconnect the black field wire from the switch.
  5. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: 5 단계, 이미지 1/1
    • Pull straight up on the field winding to remove it from the body.
결론
Brandon Schneiberg
회원 가입일: 09/26/19
255 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 12
전체 시간: 369
