주요 콘텐츠로 건너뛰기
Milwaukee Impact Wrench 9070-20 Power Cord Replacement
필요한 것
  1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: 1 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: 1 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: 1 단계, 이미지 3/3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using the T20 Torx screwdriver.
    • Remove the four 14mm screws using the same screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 2 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 2 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 2 단계, 이미지 3/3
    • Hold the device so the gray part faces directly towards you.
    • Remove the four screws on the sides using the T20 Torx screwdriver.
    • After removing all screws, use a small plastic pry bar to slide the gearbox assembly forward slightly.
  3. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 3 단계, 이미지 1/2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 3 단계, 이미지 2/2
    • Gently remove the upper clam shell from the device.
    • Lift a black colored power cord from its mount at the bottom of the device, so it can move freely.
  4. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 4 단계, 이미지 1/2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 4 단계, 이미지 2/2
    • Disconnect the brown field winding wire from the white ac power cord wire.
  5. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 5 단계, 이미지 1/2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: 5 단계, 이미지 2/2
    • Disconnect the black ac power wire from the connector on the bottom of the forward / reverse switch.
    • Remove the AC power cord and replace it with a new one.
결론
Yuna Choi
회원 가입일: 09/18/19
387 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 10
전체 시간: 338
