주요 콘텐츠로 건너뛰기
Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement
필요한 것
  1. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: 1 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: 1 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: 1 단계, 이미지 3/3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device, making the gray part face to the right.
    • Remove four 14mm screws using a T20 Torx screwdriver.
    • Remove four 18mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 2 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 2 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 2 단계, 이미지 3/3
    • Hold the device so the gearbox assembly faces directly towards you.
    • Remove the four screws using a T20 Torx screwdriver.
    • Using a plastic opening tool, pry the gearbox assembly away from the clam shell.
  3. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 3 단계, 이미지 1/1
    • After all necessary screws are removed, gently remove the upper red cover from the device.
    • Remove the gray motor and gearbox assembly.
    • Remove the gearbox gently as to not damage the brushes.
  4. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 4 단계, 이미지 1/3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 4 단계, 이미지 2/3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: 4 단계, 이미지 3/3
    • Attach a bearing removal tool to the bearing.
    • Tighten the bearing puller until the bearing comes off of the motor shaft.
    • For easier removal, lightly heat the bearing with a propane torch.
    • Heat and then press the replacement bearing onto the shaft.
결론
Yuna Choi
회원 가입일: 09/18/19
387 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 19
전체 시간: 603
