주요 콘텐츠로 건너뛰기
Milwaukee M12 2407-20 Speed Selector Lever Replacement
필요한 것
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: 1 단계, 이미지 1/1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: 2 단계, 이미지 1/1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: 3 단계, 이미지 1/3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: 3 단계, 이미지 2/3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: 3 단계, 이미지 3/3
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: 4 단계, 이미지 1/1
    • Use a spudger to pry the broken speed selector lever off the assembly.
결론
Allison Schieber
회원 가입일: 02/05/19
575 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 19
전체 시간: 1,573
