주요 콘텐츠로 건너뛰기
Milwaukee M18 2606-20 Gearbox Replacement
필요한 것
  1. Milwaukee M18 2606-20 Gearbox Replacement, Chuck: 1 단계, 이미지 1/3 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: 1 단계, 이미지 2/3 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: 1 단계, 이미지 3/3
    • Rotate the chuck counterclockwise as far as possible to loosen from the base.
  2. Milwaukee M18 2606-20 Gearbox Replacement: 2 단계, 이미지 1/2 Milwaukee M18 2606-20 Gearbox Replacement: 2 단계, 이미지 2/2
    • Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
    • Rotate the screw clockwise to loosen it.
    • The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
  3. Milwaukee M18 2606-20 Gearbox Replacement: 3 단계, 이미지 1/2 Milwaukee M18 2606-20 Gearbox Replacement: 3 단계, 이미지 2/2
    • Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
    • The Allen wrench will be used for leverage when removing the chuck.
    • When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
  4. Milwaukee M18 2606-20 Gearbox Replacement: 4 단계, 이미지 1/3 Milwaukee M18 2606-20 Gearbox Replacement: 4 단계, 이미지 2/3 Milwaukee M18 2606-20 Gearbox Replacement: 4 단계, 이미지 3/3
    • Rotate the Allen wrench counterclockwise to remove the chuck.
  5. Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: 5 단계, 이미지 1/2 Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: 5 단계, 이미지 2/2
    • Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
    • Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
  6. Milwaukee M18 2606-20 Gearbox Replacement: 6 단계, 이미지 1/3 Milwaukee M18 2606-20 Gearbox Replacement: 6 단계, 이미지 2/3 Milwaukee M18 2606-20 Gearbox Replacement: 6 단계, 이미지 3/3
    • Using the T3 Torx screwdriver, remove the four 20 mm screws from the front of the case.
  7. Milwaukee M18 2606-20 Gearbox Replacement: 7 단계, 이미지 1/2 Milwaukee M18 2606-20 Gearbox Replacement: 7 단계, 이미지 2/2
    • Peel back the sticker at the bottom of the drill handle.
  8. Milwaukee M18 2606-20 Gearbox Replacement: 8 단계, 이미지 1/2 Milwaukee M18 2606-20 Gearbox Replacement: 8 단계, 이미지 2/2
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  9. Milwaukee M18 2606-20 Gearbox Replacement: 9 단계, 이미지 1/2 Milwaukee M18 2606-20 Gearbox Replacement: 9 단계, 이미지 2/2
    • Lift the gearbox slightly and pull away from the motor to remove it from the case .
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Markus Eldridge
회원 가입일: 09/24/19
874 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 60
전체 시간: 3,761
