소개
The Milwaukee Rotary Hammer 260520 D14A 2016 gasket may need replacement if the device is leaking oil, isn't hitting hard enough, or is stalling. Keep in mind that this guide calls for accessing the gear case assembly, so expect whatever is touching the device to get exposed to grease. Some of these steps also require a considerable amount of force from the user.
Gaskets are mechanical seals that protect joined surfaces under compression by padding the space between them.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
