주요 콘텐츠로 건너뛰기
Mini Fridge Hinges Replacement
필요한 것
  1. Mini Fridge Hinges Replacement, Hinges: 1 단계, 이미지 1개 중 1개
    • Remove the plug from the outlet. Be sure to grab from the head of the cord.
  2. Mini Fridge Hinges Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all food items and shelves from the fridge.
    • Place removed contents to the side and if needed place food items in another fridge temporarily.
  3. Mini Fridge Hinges Replacement: 3 단계, 이미지 2개 중 1개 Mini Fridge Hinges Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the cover to the top hinge to access the hinge and screws. If you are unable to remove the cover with your hands, use a flathead screwdriver to pry it off.
    • Remove the three 20 mm Phillips #1 screws from beneath the cover.
  4. Mini Fridge Hinges Replacement: 4 단계, 이미지 3개 중 1개 Mini Fridge Hinges Replacement: 4 단계, 이미지 3개 중 2개 Mini Fridge Hinges Replacement: 4 단계, 이미지 3개 중 3개
    • After removing the top hinge, lift the door off of the bottom hinge.
    • Place the door and removed top hinge securely to the side.
  5. Mini Fridge Hinges Replacement: 5 단계, 이미지 2개 중 1개 Mini Fridge Hinges Replacement: 5 단계, 이미지 2개 중 2개
    • Rotate the fridge onto its side.
    • Do not turn the fridge upside down to protect the internal components of the fridge.
    • Remove the two 19 mm Phillips #1 screws and the bottom hinge.
  6. Mini Fridge Hinges Replacement: 6 단계, 이미지 1개 중 1개
    • Install the bottom replacement hinge and the two 19 mm Phillips #1 screws.
    • Turn the fridge right side up after the bottom hinge is replaced.
  7. Mini Fridge Hinges Replacement: 7 단계, 이미지 1개 중 1개
    • Place the door on the bottom hinge, aligning the hole with the hinge.
    • Install the new top hinge and the three 20 mm Philips #1 screws. Ensure the orientation of the hinge lines up with the door.
    • Tighten as needed until the fridge door opens and closes normally and is not uneven.
    • Replace the top cover and the shelving inside the fridge.
결론
This is a relatively easy fix and is easily repeatable. The replacement parts are inexpensive. We hope this guide extends the life of a mini fridge and expands your understanding of the topic.
다른 한 분이 해당 안내서를 완성하였습니다.
1가이드 댓글
My fridge is not working Death ho gaya h bikul kuch bbi n chal rha h
Prince Singh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 29
지난 30일: 122
전체 시간: 5,184
