주요 콘텐츠로 건너뛰기
Minolta Dimage Xt Capture Button Replacement
필요한 것
  1. Minolta Dimage Xt Capture Button Replacement, Casing: 1 단계, 이미지 3개 중 1개 Minolta Dimage Xt Capture Button Replacement, Casing: 1 단계, 이미지 3개 중 2개 Minolta Dimage Xt Capture Button Replacement, Casing: 1 단계, 이미지 3개 중 3개
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Capture Button Replacement: 2 단계, 이미지 3개 중 1개 Minolta Dimage Xt Capture Button Replacement: 2 단계, 이미지 3개 중 2개 Minolta Dimage Xt Capture Button Replacement: 2 단계, 이미지 3개 중 3개
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Capture Button Replacement, Capture Button: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Choosing the front half of the casing, locate the capture button on the top.
    • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
  4. Minolta Dimage Xt Capture Button Replacement: 4 단계, 이미지 1개 중 1개
    • The button will spring free. The capture device consists of the plastic button and a small metal spring.
    • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
결론
Reassemble the casing by reversing steps 1 and 2.
작성자
6다른 기여자 명과 함께
Megan Milam
회원 가입일: 03/11/13
56 평판
안내서 5개를 작성함
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 회원
CLEM-BENSON-S13S12G4
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 631
