주요 콘텐츠로 건너뛰기
Minolta Dimage Xt Casing Replacement
필요한 것
  1. Minolta Dimage Xt Casing Replacement, Casing: 1 단계, 이미지 1/3 Minolta Dimage Xt Casing Replacement, Casing: 1 단계, 이미지 2/3 Minolta Dimage Xt Casing Replacement, Casing: 1 단계, 이미지 3/3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Casing Replacement: 2 단계, 이미지 1/3 Minolta Dimage Xt Casing Replacement: 2 단계, 이미지 2/3 Minolta Dimage Xt Casing Replacement: 2 단계, 이미지 3/3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
결론
To reassemble your device, follow these instructions in reverse order. The outer casing must be properly in place and screws tight to protect the internal hardware.
Megan Milam
회원 가입일: 03/11/13
28 평판
안내서 5개 작성하였습니다
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 회원
CLEM-BENSON-S13S12G4
3 회원들
안내서 14개 작성하였습니다
댓글 한 개
How to reattach the ribbon????
rosybrier - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 428
