주요 콘텐츠로 건너뛰기
Minolta Dimage Xt Flashbulb and Housing Replacement
필요한 것
  1. Minolta Dimage Xt Flashbulb and Housing Replacement, Casing: 1 단계, 이미지 3개 중 1개 Minolta Dimage Xt Flashbulb and Housing Replacement, Casing: 1 단계, 이미지 3개 중 2개 Minolta Dimage Xt Flashbulb and Housing Replacement, Casing: 1 단계, 이미지 3개 중 3개
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flashbulb and Housing Replacement: 2 단계, 이미지 3개 중 1개 Minolta Dimage Xt Flashbulb and Housing Replacement: 2 단계, 이미지 3개 중 2개 Minolta Dimage Xt Flashbulb and Housing Replacement: 2 단계, 이미지 3개 중 3개
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flashbulb and Housing Replacement, Flashbulb and Housing: 3 단계, 이미지 2개 중 1개 Minolta Dimage Xt Flashbulb and Housing Replacement, Flashbulb and Housing: 3 단계, 이미지 2개 중 2개
    • Remove 2mm screws connecting the flash housing to the main components of the camera.
    • Use a Philips #00 screwdriver to remove the black 2.0mm (4 instances) screws .
  4. Minolta Dimage Xt Flashbulb and Housing Replacement: 4 단계, 이미지 3개 중 1개 Minolta Dimage Xt Flashbulb and Housing Replacement: 4 단계, 이미지 3개 중 2개 Minolta Dimage Xt Flashbulb and Housing Replacement: 4 단계, 이미지 3개 중 3개
    • Use the spudger to push the black plastic hooks through the circuit board to release the flash housing.
    • Once the screws have been removed, pull the circuit board away from the body of the camera.
    • Wires will keep it from completely detaching.
    • Pull the housing away from the circuit board.
결론
To reassemble device, follow steps in reverse order. This will require the reattachment of wires from the camera to the flashbulb casing.
작성자
6다른 기여자 명과 함께
Keith Sechrist
회원 가입일: 03/11/13
22 평판
안내서 2개를 작성함
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 회원
CLEM-BENSON-S13S12G4
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 746
