주요 콘텐츠로 건너뛰기
Minolta Dimage Xt LCD Screen Disassembly
필요한 것
  1. Minolta Dimage Xt LCD Screen Disassembly, Casing: 1 단계, 이미지 3개 중 1개 Minolta Dimage Xt LCD Screen Disassembly, Casing: 1 단계, 이미지 3개 중 2개 Minolta Dimage Xt LCD Screen Disassembly, Casing: 1 단계, 이미지 3개 중 3개
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt LCD Screen Disassembly: 2 단계, 이미지 3개 중 1개 Minolta Dimage Xt LCD Screen Disassembly: 2 단계, 이미지 3개 중 2개 Minolta Dimage Xt LCD Screen Disassembly: 2 단계, 이미지 3개 중 3개
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt LCD Screen Disassembly, LCD Screen: 3 단계, 이미지 1개 중 1개
    • The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
    • The screen also has a ribbon wire connected at the bottom of the screen.
  4. Minolta Dimage Xt LCD Screen Disassembly: 4 단계, 이미지 2개 중 1개 Minolta Dimage Xt LCD Screen Disassembly: 4 단계, 이미지 2개 중 2개
    • Detach the connector at the bottom from the LCD screen.
    • Starting from the side or a corner gently slide the spudger underneath the screen.
    • Press the tip of the spudger down as far is you can and slowly pry the LCD screen away from the bracket.
  5. Minolta Dimage Xt LCD Screen Disassembly: 5 단계, 이미지 1개 중 1개
    • The screen is not detached. Wires are still connecting the screen to the camera at the bottom corners, but it is removed from the bracket.
    • Check to make sure the wires are connected, so it will receive proper power supply.
    • To remove the bracket from the LCD screen, remove two 1.5 mm screws using the Phillips #00 screwdriver.
결론
To install a new LCD screen you will have to reconnect the wires and properly place them in the bracket. Make sure to reattach the ribbon wire before finishing repairs.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Keith Sechrist
회원 가입일: 03/11/13
22 평판
안내서 2개를 작성함
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 회원
CLEM-BENSON-S13S12G4
3 회원들
안내서 14개를 작성함
1가이드 댓글
Great procedure, thank you.
Do you know where I can buy the LCD replacement part?
I have a Konica Minolta Dimage X1 8.0 MP
mscir - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 118
전체 시간: 1,471
