이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The LCD screen is held into the camera by the outer casing and an internal bracket. It is one component, so there isn't a way to just replace the LCD screen. Once screen is out of the bracket, wires must be removed to completely remove the LCD screen.
필요한 것
The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
The screen is not detached, but is removed from its bracket. Note: Wires are still connecting the screen to the camera at the bottom corners.
Check to make sure wires are connected, so it will receive proper power supply.
To remove the bracket for the LCD screen, remove these 1.5 mm (2 instances) screws using the #00 Phillips screwdriver.
To install new LCD screen you will have to reconnect the wires and properly place in bracket. Make sure to reattach the ribbon wire before finishing repairs.
다른 한 분이 해당 안내서를 완성하였습니다.
