이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Then, carefully pry apart the front and back outer casing away from the internal components.
The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
Detach the connector at the bottom from the LCD screen.
Starting from the side or a corner gently slide the spudger underneath the screen.
Press the tip of the spudger down as far is you can and slowly pry the LCD screen away from the bracket.
Check to make sure the wires are connected, so it will receive proper power supply.
To remove the bracket from the LCD screen, remove two 1.5 mm screws using the Phillips #00 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
