주요 콘텐츠로 건너뛰기
Minolta Dimage Xt SD Card Replacement
  1. Minolta Dimage Xt SD Card Replacement, SD Card: 1 단계, 이미지 2개 중 1개 Minolta Dimage Xt SD Card Replacement, SD Card: 1 단계, 이미지 2개 중 2개
    • Locate the latch labeled BATT SD CARD on the right side of the camera.
    • Push the latch in the direction of the arrow, and it will spring open.
  2. Minolta Dimage Xt SD Card Replacement: 2 단계, 이미지 2개 중 1개 Minolta Dimage Xt SD Card Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the SD card into the smaller of the two slots. The metallic connectors should enter the camera first and the label of the SD card can be seen from a front view of the camera.
    • Push the card all the way into the slot until there is a click, and the card stays in place.
    • To remove the SD card, push the card down and release. The card will pop up and can be pulled the rest of the way out.
결론
When the card has been removed/inserted, push the latch down, and it will lock into place.
작성자
4다른 기여자 명과 함께
Megan Milam
회원 가입일: 03/11/13
56 평판
안내서 5개를 작성함
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 회원
CLEM-BENSON-S13S12G4
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 1,535
