주요 콘텐츠로 건너뛰기
Minolta Maxxum QTSI Tripod Mount Replacement
필요한 것
  1. Minolta Maxxum QTSI Tripod Mount Replacement, Tripod Mount: 1 단계, 이미지 1/1
    • With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
  2. Minolta Maxxum QTSI Tripod Mount Replacement: 2 단계, 이미지 1/2 Minolta Maxxum QTSI Tripod Mount Replacement: 2 단계, 이미지 2/2
    • Once all the screws are removed, the panel should easily come off.
    • Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
    • Pull the bottom panel towards you, it should come off easily.
  3. Minolta Maxxum QTSI Tripod Mount Replacement: 3 단계, 이미지 1/1
    • The tripod socket is visible when the bottom panel is removed.
    • Remove the (3) black Phillips #00 6.25mm screws from the tripod socket.
    • When the screws are removed, the tripod socket is free and can easily be lost.
  4. Minolta Maxxum QTSI Tripod Mount Replacement: 4 단계, 이미지 1/2 Minolta Maxxum QTSI Tripod Mount Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to gently remove the tripod socket, and replace it.
결론
Jordan Ellery
회원 가입일: 10/10/16
388 평판
안내서 3개 작성하였습니다
Sam Houston State, Team 12-4, Blackburne Fall 2016 Sam Houston State, Team 12-4, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 363
