주요 콘텐츠로 건너뛰기
Minolta Maxxum STsi Back Clock Button Replacement
필요한 것
  1. Minolta Maxxum STsi Back Clock Button Replacement, Back Clock Button: 1 단계, 이미지 1/1
    • Open the back panel by firmly pressing up on the back-cover release on the lower right side of the camera.
  2. Minolta Maxxum STsi Back Clock Button Replacement: 2 단계, 이미지 1/3 Minolta Maxxum STsi Back Clock Button Replacement: 2 단계, 이미지 2/3 Minolta Maxxum STsi Back Clock Button Replacement: 2 단계, 이미지 3/3
    • Remove the black case by gently lifting it with your fingers and rotating counterclockwise.
  3. Minolta Maxxum STsi Back Clock Button Replacement: 3 단계, 이미지 1/2 Minolta Maxxum STsi Back Clock Button Replacement: 3 단계, 이미지 2/2
    • Remove the five black Phillips #00 2.5 mm screws from the back panel.
    • Also remove the two black Phillips #00 5.0 mm screws from the back panel.
  4. Minolta Maxxum STsi Back Clock Button Replacement: 4 단계, 이미지 1/1
    • Use the tweezers to carefully peel back the adhesive foam connecting the back panel to the case and remove the panel.
  5. Minolta Maxxum STsi Back Clock Button Replacement: 5 단계, 이미지 1/2 Minolta Maxxum STsi Back Clock Button Replacement: 5 단계, 이미지 2/2
    • Use the tweezers to carefully peel off the rubber clock button.
결론
Jacobe Labog
회원 가입일: 05/02/15
301 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-12, Amido Spring 2015 Cal Poly, Team 14-12, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G12
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 444
