주요 콘텐츠로 건너뛰기
Minolta QTsi Maxxum Eyelet Straps Replacement
필요한 것
  1. Minolta QTsi Maxxum Eyelet Straps Replacement, Eyelet Straps: 1 단계, 이미지 1/1
    • The battery compartment is located on the bottom panel of the camera.
    • Use a coin to open the battery compartment of the camera.
    • Twist the coin counterclockwise in order to release the latch.
  2. Minolta QTsi Maxxum Eyelet Straps Replacement: 2 단계, 이미지 1/1
    • Once the compartment is open, grab the batteries and pull them out of the compartment.
    • There should be two batteries inside the battery compartment.
  3. Minolta QTsi Maxxum Eyelet Straps Replacement: 3 단계, 이미지 1/1
    • With a screwdriver, remove the (7) black Phillips #00 5mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
    • Once all the screws are removed, the panel should easily come off.
  4. Minolta QTsi Maxxum Eyelet Straps Replacement: 4 단계, 이미지 1/1
    • Once the bottom panel is removed, the one screw at the bottom of the battery compartment should be visible.
    • Remove the (1) black Phillips #00 5mm screw from the battery compartment.
  5. Minolta QTsi Maxxum Eyelet Straps Replacement: 5 단계, 이미지 1/1
    • Press the release button on the side panel to pop open the back piece of the camera.
  6. Minolta QTsi Maxxum Eyelet Straps Replacement: 6 단계, 이미지 1/1
    • Once the back panel is open, the chamber containing one screw should be visible.
    • Remove the (1) black Phillips #00 5mm screw inside.
  7. Minolta QTsi Maxxum Eyelet Straps Replacement: 7 단계, 이미지 1/2 Minolta QTsi Maxxum Eyelet Straps Replacement: 7 단계, 이미지 2/2
    • Take out the (2) Phillips #00 5mm screws on the right side panel of the camera.
    • Remove the (1) Phillips #00 5mm screw on the left side panel of the camera.
    • Remove the side panels from the camera and set them aside .
    • Be careful when removing side panels. There is a plastic piece and spring underneath the left side panel that could get lost.
  8. Minolta QTsi Maxxum Eyelet Straps Replacement: 8 단계, 이미지 1/1
    • When looking at the back of the camera, there should be a single screw on each side of the viewfinder.
    • Remove these (2) silver Phillips #00 5mm screws from each side of the viewfinder.
  9. Minolta QTsi Maxxum Eyelet Straps Replacement: 9 단계, 이미지 1/1
    • When looking at the top of the camera, the flash hood is visible.
    • Lift the flash hood and remove the (1) silver Phillips #00 5mm screw.
  10. Minolta QTsi Maxxum Eyelet Straps Replacement: 10 단계, 이미지 1/2 Minolta QTsi Maxxum Eyelet Straps Replacement: 10 단계, 이미지 2/2
    • The top panel of the camera should now be easy to pop off. If it is not, make sure that all screws listed in steps 3-9 are removed.
    • Lift the top panel away from the rest of the camera.
    • Be careful when removing the top panel because there are wires connected to it.
  11. Minolta QTsi Maxxum Eyelet Straps Replacement: 11 단계, 이미지 1/1
    • Once all parts of the camera are removed, both eyelet straps should be visible on the top left and right sides.
    • Unscrew the (4) black Phillips #00 5mm screws to remove each eyelet strap holder and replace them.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Maya Van Londen
회원 가입일: 10/10/16
315 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 12-4, Blackburne Fall 2016 Sam Houston State, Team 12-4, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 354
