주요 콘텐츠로 건너뛰기
Minolta QTsi Maxxum Lens Replacement
필요한 것
  1. Minolta QTsi Maxxum Lens Replacement, Lens: 1 단계, 이미지 1/2 Minolta QTsi Maxxum Lens Replacement, Lens: 1 단계, 이미지 2/2
    • The lens release button is located on the right front side of the camera.
    • Remove the lens from the camera by pushing the lens release button.
  2. Minolta QTsi Maxxum Lens Replacement: 2 단계, 이미지 1/1
    • The detached module has multiple screws that must be removed in order to reach the lens.
    • Once detached, remove the (4) black Phillips #00 5mm screws from the outer rim of the module.
    • Next, remove the (2) remaining black Phillips #00 5mm screws.
  3. Minolta QTsi Maxxum Lens Replacement: 3 단계, 이미지 1/2 Minolta QTsi Maxxum Lens Replacement: 3 단계, 이미지 2/2
    • Once all screws have been removed, take the back piece off of the lens and replace it.
    • This piece should come off easily without using any tools.
    • There is film underneath the last 2 screws that are removed so be careful when taking it out because it could rip.
결론
Jordan Ellery
회원 가입일: 10/10/16
388 평판
안내서 3개 작성하였습니다
Sam Houston State, Team 12-4, Blackburne Fall 2016 Sam Houston State, Team 12-4, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 594
