주요 콘텐츠로 건너뛰기
Minolta QTsi Maxxum Shutter Button Replacement
필요한 것
  1. Minolta QTsi Maxxum Shutter Button Replacement, Shutter Button: 1 단계, 이미지 1개 중 1개
    • Locate the battery compartment on the bottom panel of the camera.
    • Open the battery door by using a coin.
    • In the counterclockwise direction, twist the coin in the battery door groove to open it.
  2. Minolta QTsi Maxxum Shutter Button Replacement: 2 단계, 이미지 1개 중 1개
    • Two batteries are located inside the battery chamber.
    • Remove the two batteries from the battery chamber by picking them up.
  3. Minolta QTsi Maxxum Shutter Button Replacement: 3 단계, 이미지 1개 중 1개
    • There is a screw located underneath the batteries in the battery compartment.
    • Unscrew and remove the (1) black Phillips #00 5mm screw from the battery compartment.
    • Ensure good lighting before attempting to remove this screw because it is hard to see inside the compartment.
  4. Minolta QTsi Maxxum Shutter Button Replacement: 4 단계, 이미지 1개 중 1개
    • From underneath the flash assembly, remove the (1) black Phillips #00 5mm screw
    • Be careful because you can lose the screw
  5. Minolta QTsi Maxxum Shutter Button Replacement: 5 단계, 이미지 1개 중 1개
    • The only screws remaining that hold the top panel of the camera in place are located next to the view finder.
    • Remove the (2) black Phillips #00 5mm screws from both sides of the view finder.
  6. Minolta QTsi Maxxum Shutter Button Replacement: 6 단계, 이미지 2개 중 1개 Minolta QTsi Maxxum Shutter Button Replacement: 6 단계, 이미지 2개 중 2개
    • The top panel of the camera should now be easy to lift off. If it is not, make sure that all screws and attachments, listed in steps 1-5, have been removed.
    • Once all screws are removed, lift the top panel from the camera.
    • Be careful when removing the top panel because there are wires connected to it.
  7. Minolta QTsi Maxxum Shutter Button Replacement: 7 단계, 이미지 1개 중 1개
    • Use a metal spudger to push the button out of its socket so that you can place a new one in its place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jordan Ellery
회원 가입일: 10/10/16
388 평판
안내서 3개를 작성함
Sam Houston State, Team 12-4, Blackburne Fall 2016 Sam Houston State, Team 12-4, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 673
