주요 콘텐츠로 건너뛰기
Minolta X-370 Battery Replacement
필요한 것
  1. Minolta X-370 Battery Replacement, Minolta X-370 Battery Replacement: 1 단계, 이미지 1/2 Minolta X-370 Battery Replacement, Minolta X-370 Battery Replacement: 1 단계, 이미지 2/2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Minolta X-370 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - 답글
결론
다른 4명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 04/19/11
525 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-7, Regan Spring 2011 Cal Poly, Team 8-7, Regan Spring 2011 회원
CPSU-REGAN-S11S8G7
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Hi there, i'm a bit stuck, in my 35mm SLR i was taking a shot and the batteries died, leaving the mirror stuck in the up position, i've changed the batteries and the release for the shutter won't click, i can't advance the film lever and so it's a sitting duck at the moment. They're brand new batteries but because the mirror is up i can't even see if the metering works. because i'm half way through a roll of film i don't want to open the back and ruin it so i'm wondering if there's any way to get the shutter to release again or to get the mirror back down, i don't mind loosing a few blank exposures but again i really wouldn't want to ruin the film. Many thanks and i hope you can get back to me,
Cameron
Cameron Tyson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 40
30일 전: 137
전체 시간: 20,577
