주요 콘텐츠로 건너뛰기
Mio ALPHA 2 Battery Replacement
필요한 것
  1. Mio ALPHA 2 Battery Replacement, Battery: 1 단계, 이미지 1/2 Mio ALPHA 2 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the 4 JIS 00 6.71 mm screws.
  2. Mio ALPHA 2 Battery Replacement: 2 단계, 이미지 1/1
    • Pull off the back cover of the watch after the 4 screws are removed from the first step.
    • Be careful not to remove the Data Strip (Brown Strip) from either chip.
  3. Mio ALPHA 2 Battery Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use some tweezers to remove the small white clip for the battery from the circuit board.
  4. Mio ALPHA 2 Battery Replacement: 4 단계, 이미지 1/1
    • Slowly peel the battery off from the back cover of the watch.
    • There is double sided tape on the back side. Make sure to not tear up the tape. If the double sided tape is not reusable, replace with new tape.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
David Soder
회원 가입일: 11/20/17
155 평판
안내서 1개 작성함
IUPUI, Team S22-G3, Bayer Fall 2017 IUPUI, Team S22-G3, Bayer Fall 2017 회원
IUPUI-BAYER-F17S22G3
4 회원들
안내서 2개 작성하였습니다
댓글 4개
What battery should I buy? Can you provide any specs about the battery itself?
Tabitha Romero - 답글
The Mio support team tells: “Unfortunatley, ALPHA 2 doesn't have replacable batteries “.
Any idea where we can buy such battery ?
vanlaetb - 답글
hi i managed to purchase the battery and replace it via Ali Express website. Search for battery size 302530 3.7v 300 mah Lithium . Thickness 3mm, width 25mm, length 30mm.
Take note when you replace the battery the wire that comes with the new battery wire will be too thick to insert into the mini small white clip. What i did was to cut off the old wire from the old battery and connect it with the new battery wire.
lhy011 -
Hi, Can you share me the link to buy the battery?
Thank you!!!
amoreno - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 32
전체 시간: 3,017
