주요 콘텐츠로 건너뛰기
Mission Hammr Bow String and Cables Replacement
  1. Mission Hammr Bow String and Cables Replacement, Strings and Cables: 1 단계, 이미지 1/1
    • Align the arms of the bow press with the limbs of the bow.
    • Ensure the bow press and bow arms are safe to use for this particular bow.
  2. Mission Hammr Bow String and Cables Replacement: 2 단계, 이미지 1/1
    • Slowly compress the bow press until the string has some slack similar to what's shown in the picture.
    • DO NOT press the bow anymore than you have to. This could result in damage to the bow and the bow press.
  3. Mission Hammr Bow String and Cables Replacement: 3 단계, 이미지 1/1
    • Before you remove the string or cables make sure you know where everything goes for replacement. Take a picture if needed.
  4. Mission Hammr Bow String and Cables Replacement: 4 단계, 이미지 1/1
    • Remove the string.
    • This is the easiest piece to put on and take off. Taking this off first will keep it out of the way so you can access the cables a bit more cleanly.
  5. Mission Hammr Bow String and Cables Replacement: 5 단계, 이미지 1/3 Mission Hammr Bow String and Cables Replacement: 5 단계, 이미지 2/3 Mission Hammr Bow String and Cables Replacement: 5 단계, 이미지 3/3
    • Now remove the cables one at a time.
    • After removing an old cable, immediately replace it with a new one. Doing this will make it easier to ensure you are replacing the cables in the correct spots.
    • The place the cable hooks onto the cam is labeled with a C. The string goes where it's imprinted with an S.
  6. Mission Hammr Bow String and Cables Replacement: 6 단계, 이미지 1/1
    • Once both sets of cables are replaced, make sure they are in the correct grooves before continuing.
  7. Mission Hammr Bow String and Cables Replacement: 7 단계, 이미지 1/2 Mission Hammr Bow String and Cables Replacement: 7 단계, 이미지 2/2
    • Replace the string.
  8. Mission Hammr Bow String and Cables Replacement: 8 단계, 이미지 1/1
    • Now with the string on and in the correct groove check through everything once more.
    • With the bow press, slowly tighten the strings and cables until it looks like it did before the replacement.
    • Use your before picture for a comparison to make sure it's correct.
  9. Mission Hammr Bow String and Cables Replacement: 9 단계, 이미지 1/1
    • Now with the pressure back on the bow everything should be ready to go.
    • Double check to make sure the cables align in the tuning holes and the strings and cables have successfully been replaced.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mathew Reed
회원 가입일: 03/23/21
187 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G12, O'Connell Spring 2021 UMass Dartmouth, Team S1-G12, O'Connell Spring 2021 회원
UMASSD-O'CONNELL-S21S1G12
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 568
