주요 콘텐츠로 건너뛰기
Mission Hammr Bow String and Cables Replacement
  1. Mission Hammr Bow String and Cables Replacement, Strings and Cables: 1 단계, 이미지 1개 중 1개
    • Begin by aligning the small, grey arms of the bow press with the limbs of the bow.
    • Make sure both the bow press and the bow are safe to use with this particular bow.
  2. Mission Hammr Bow String and Cables Replacement: 2 단계, 이미지 1개 중 1개
    • Slowly compress the bow press until the string has some slack, as shown in the picture.
    • Do not compress the bow any more than necessary, as this could damage the bow or the bow press.
  3. Mission Hammr Bow String and Cables Replacement: 3 단계, 이미지 1개 중 1개
    • Before removing the string or cables, note where each component goes for reassembly. Take a photo if needed.
  4. Mission Hammr Bow String and Cables Replacement: 4 단계, 이미지 1개 중 1개
    • First, carefully remove the string.
    • The string is the easiest part to remove and reinstall, and taking it off first keeps it out of the way while you work on the cables.
  5. Mission Hammr Bow String and Cables Replacement: 5 단계, 이미지 3개 중 1개 Mission Hammr Bow String and Cables Replacement: 5 단계, 이미지 3개 중 2개 Mission Hammr Bow String and Cables Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the cables one at a time.
    • After removing each old cable, immediately replace it with the new one to ensure correct placement.
    • The cable hooks onto the cam at the point labeled C.
    • The string attaches at the point labeled S.
  6. Mission Hammr Bow String and Cables Replacement: 6 단계, 이미지 1개 중 1개
    • Once both sets of cables are replaced, double-check that they sit correctly in their grooves before proceeding.
  7. Mission Hammr Bow String and Cables Replacement: 7 단계, 이미지 2개 중 1개 Mission Hammr Bow String and Cables Replacement: 7 단계, 이미지 2개 중 2개
    • Finally, replace the string.
  8. Mission Hammr Bow String and Cables Replacement: 8 단계, 이미지 1개 중 1개
    • Now with the string on and in the correct groove check through everything once more.
    • With the bow press, slowly tighten the strings and cables until it looks like it did before the replacement.
    • Use your before picture for a comparison to make sure it's correct.
  9. Mission Hammr Bow String and Cables Replacement: 9 단계, 이미지 1개 중 1개
    • Now with the pressure back on the bow everything should be ready to go.
    • Double check to make sure the cables align in the tuning holes and the strings and cables have successfully been replaced.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mathew Reed
회원 가입일: 03/23/21
187 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G12, O'Connell Spring 2021 UMass Dartmouth, Team S1-G12, O'Connell Spring 2021 회원
UMASSD-O'CONNELL-S21S1G12
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 860
