주요 콘텐츠로 건너뛰기
MistAire Humidifier Cap Spring Replacement
필요한 것
  1. MistAire Humidifier Cap Spring Replacement, Cap Spring: 1 단계, 이미지 2개 중 1개 MistAire Humidifier Cap Spring Replacement, Cap Spring: 1 단계, 이미지 2개 중 2개
    • Lift the blue tank off of the base of the humidifier.
    • The two parts are not attached or snapped together, so they should separate easily.
  2. MistAire Humidifier Cap Spring Replacement: 2 단계, 이미지 3개 중 1개 MistAire Humidifier Cap Spring Replacement: 2 단계, 이미지 3개 중 2개 MistAire Humidifier Cap Spring Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the tank upside down.
    • Turn the round cap counterclockwise to completely unscrew it.
  3. MistAire Humidifier Cap Spring Replacement: 3 단계, 이미지 2개 중 1개 MistAire Humidifier Cap Spring Replacement: 3 단계, 이미지 2개 중 2개
    • There is a white plastic rod that goes through the center of the cap. It has a flat, circular end and a pointed end. The pointed end has a small, blue, silicone ring around it.
    • Push the flat side of the rod until the pointed end protrudes from the other side of the cap.
  4. MistAire Humidifier Cap Spring Replacement: 4 단계, 이미지 3개 중 1개 MistAire Humidifier Cap Spring Replacement: 4 단계, 이미지 3개 중 2개 MistAire Humidifier Cap Spring Replacement: 4 단계, 이미지 3개 중 3개
    • While still pushing on the rod, tug the small, blue, silicone ring completely off of the pointed end.
  5. MistAire Humidifier Cap Spring Replacement: 5 단계, 이미지 2개 중 1개 MistAire Humidifier Cap Spring Replacement: 5 단계, 이미지 2개 중 2개
    • Once the ring is off, pull the rod and spring out from the center of the cap.
  6. MistAire Humidifier Cap Spring Replacement: 6 단계, 이미지 2개 중 1개 MistAire Humidifier Cap Spring Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the broken spring off of the rod.
    • The spring should come off easily.
  7. MistAire Humidifier Cap Spring Replacement: 7 단계, 이미지 2개 중 1개 MistAire Humidifier Cap Spring Replacement: 7 단계, 이미지 2개 중 2개
    • Slide a new 10x6x19mm Tapered Compression Spring around the rod.
    • Ensure the narrower end of the cone-shaped spring goes first.
  8. MistAire Humidifier Cap Spring Replacement: 8 단계, 이미지 2개 중 1개 MistAire Humidifier Cap Spring Replacement: 8 단계, 이미지 2개 중 2개
    • Pinch the spring gently to secure it around the rod.
    • Push the pointed end of the rod all the way through the center hole of the cap. Hold it there for Step 9.
  9. MistAire Humidifier Cap Spring Replacement: 9 단계, 이미지 3개 중 1개 MistAire Humidifier Cap Spring Replacement: 9 단계, 이미지 3개 중 2개 MistAire Humidifier Cap Spring Replacement: 9 단계, 이미지 3개 중 3개
    • Push the small blue ring back onto the pointed end of the rod.
    • You should hear a snap when it’s secured.
  10. MistAire Humidifier Cap Spring Replacement: 10 단계, 이미지 3개 중 1개 MistAire Humidifier Cap Spring Replacement: 10 단계, 이미지 3개 중 2개 MistAire Humidifier Cap Spring Replacement: 10 단계, 이미지 3개 중 3개
    • Now that you have fixed the spring-loaded cap, screw the cap clockwise back onto the bottom of the tank.
  11. MistAire Humidifier Cap Spring Replacement: 11 단계, 이미지 3개 중 1개 MistAire Humidifier Cap Spring Replacement: 11 단계, 이미지 3개 중 2개 MistAire Humidifier Cap Spring Replacement: 11 단계, 이미지 3개 중 3개
    • Place the tank back onto the humidifier base.
    • You have now successfully replaced the spring in the MistAire Humidifier!
결승점
작성자
3다른 기여자 명과 함께
Abby
회원 가입일: 01/31/24
193 평판
안내서 1개를 작성함
UC Davis, Team 1-1, Andersen Winter 2024 UC Davis, Team 1-1, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S1G1
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 33
지난 30일: 96
전체 시간: 771
