주요 콘텐츠로 건너뛰기
Mitsubishi Diamondpoint NXM76LCD Speaker Replacement
필요한 것
  1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: 1 단계, 이미지 1/3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: 1 단계, 이미지 2/3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: 1 단계, 이미지 3/3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the 5 screws: 2 단계, 이미지 1/1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: 3 단계, 이미지 1/3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: 3 단계, 이미지 2/3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: 3 단계, 이미지 3/3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: 4 단계, 이미지 1/2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: 4 단계, 이미지 2/2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 5 단계, 이미지 1/2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 5 단계, 이미지 2/2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: 6 단계, 이미지 1/2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: 6 단계, 이미지 2/2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 7 단계, 이미지 1/2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 7 단계, 이미지 2/2
    • Remove the Phillips #2 screws from the speaker(s).
  8. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 8 단계, 이미지 1/3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 8 단계, 이미지 2/3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 8 단계, 이미지 3/3
    • Pull the speaker off the slots.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Padraic Hoselton
회원 가입일: 08/22/17
4,171 평판
안내서 12개 작성하였습니다
Master Techs Master Techs 회원
Community
315 회원들
안내서 1,326개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 69
